It is currently Mon Aug 10, 2026 9:02 pm
 Post subject: Help - Grounding?
PostPosted: Thu Dec 20, 2007 3:49 am
How is the dash physically grounded? Through the firewall? By a wire or by weld? The lights in the cab are very dim, but brighten up considerably when the engine is started. I also notice the lights behind the gauges are very weak. I suspect grounding issues. I will run separate wire to th e places that need them if I know all the places that might loose their ground over time and rust.
TIA
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Thu Dec 20, 2007 7:14 am
The dash is bolted, metal on metal (with some paint?) to the bulkheads above the door hinges, and via the pedal assembly to the firewall.
