It is currently Sat May 16, 2026 11:30 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
PostPosted: Sat Sep 01, 2001 3:41 pm
There used to be a blockoff plate available for use with '73-up Slant-6 intake manifolds if you didn't want/need to run EGR. I used to have the part number! Anyone have one, or know the P/N? Need one in a hurry...
DS
redbear@vrx.net
PostPosted: Sat Sep 01, 2001 7:17 pm
Don't know a part number. You'll most likely find one on a 1977-78 truck or van, expecially if it has a higher GVW rating. Or look in a tractor/farm equipment salvage yard, many swathers (hay cutting machine) used Slant 6's and the 1975-up engines will have that plate on too.
If you have the old EGR valve just cut out a pice of sheet metal (roofing tin or what ever) and just make two holes for the bolts / studs. Install it under the EGR valve until you can find a block off plate.
You could also make one from a piece of steel bar stock. Just cut off a piece, drill two holes in it and you are done.
cfield@ll.net
PostPosted: Sat Sep 01, 2001 8:39 pm
: Don't know a part number.
The 1976 Mopar Parts Catalog lists the following part number for a 225 /6 EGR Valve Flange Cover:
3671447. It's applications are for Plymouth A-body cars and Dodge Coronets only...
Good luck Dan
-DusterIdiot
res0aus2@verizon.net
PostPosted: Mon Sep 03, 2001 7:08 am
: Don't know a part number. You'll most likely
: find one on a 1977-78 truck or van,
: expecially if it has a higher GVW rating. Or
: look in a tractor/farm equipment salvage
: yard, many swathers (hay cutting machine)
: used Slant 6's and the 1975-up engines will
: have that plate on too.
: If you have the old EGR valve just cut out a
: pice of sheet metal (roofing tin or what
: ever) and just make two holes for the bolts
: / studs. Install it under the EGR valve
: until you can find a block off plate.
: You could also make one from a piece of steel
: bar stock. Just cut off a piece, drill two
: holes in it and you are done.
That's what I did. Just used a gasket for a template, took about 5 minutes.
aschumers@aol.com
PostPosted: Mon Sep 03, 2001 8:36 am
I made one from a piece of 1/4" aluminum and made a gasket to fit. No problems and it lasted for years.
PostPosted: Mon Sep 03, 2001 12:03 pm
: The 1976 Mopar Parts Catalog lists the
: following part number for a 225 /6 EGR Valve
: Flange Cover: 3671447.
Thanks!
DS
redbear@vrx.net
