| EGR Block-off Plate needed https://slantsix.org/forum/viewtopic.php?t=2627 |
| Author: | SL6 Daniel [ Sat Sep 01, 2001 3:41 pm ] |
| Post subject: | EGR Block-off Plate needed |
There used to be a blockoff plate available for use with '73-up Slant-6 intake manifolds if you didn't want/need to run EGR. I used to have the part number! Anyone have one, or know the P/N? Need one in a hurry... DS redbear@vrx.net |
| Author: | Craig [ Sat Sep 01, 2001 7:17 pm ] |
| Post subject: | Re: EGR Block-off Plate needed |
Don't know a part number. You'll most likely find one on a 1977-78 truck or van, expecially if it has a higher GVW rating. Or look in a tractor/farm equipment salvage yard, many swathers (hay cutting machine) used Slant 6's and the 1975-up engines will have that plate on too. If you have the old EGR valve just cut out a pice of sheet metal (roofing tin or what ever) and just make two holes for the bolts / studs. Install it under the EGR valve until you can find a block off plate. You could also make one from a piece of steel bar stock. Just cut off a piece, drill two holes in it and you are done. cfield@ll.net |
| Author: | DusterIdiot [ Sat Sep 01, 2001 8:39 pm ] |
: Don't know a part number.
The 1976 Mopar Parts Catalog lists the following part number for a 225 /6 EGR Valve Flange Cover: 3671447. It's applications are for Plymouth A-body cars and Dodge Coronets only... Good luck Dan -DusterIdiot res0aus2@verizon.net |
| Author: | dschumers [ Mon Sep 03, 2001 7:08 am ] |
: Don't know a part number. You'll most likely : find one on a 1977-78 truck or van, : expecially if it has a higher GVW rating. Or : look in a tractor/farm equipment salvage : yard, many swathers (hay cutting machine) : used Slant 6's and the 1975-up engines will : have that plate on too. : : If you have the old EGR valve just cut out a : pice of sheet metal (roofing tin or what : ever) and just make two holes for the bolts : / studs. Install it under the EGR valve : until you can find a block off plate. : : You could also make one from a piece of steel : bar stock. Just cut off a piece, drill two : holes in it and you are done. That's what I did. Just used a gasket for a template, took about 5 minutes. aschumers@aol.com |
| Author: | Gary [ Mon Sep 03, 2001 8:36 am ] |
I made one from a piece of 1/4" aluminum and made a gasket to fit. No problems and it lasted for years. |
| Author: | SL6 Daniel [ Mon Sep 03, 2001 12:03 pm ] |
: The 1976 Mopar Parts Catalog lists the : following part number for a 225 /6 EGR Valve : Flange Cover: 3671447. Thanks! DS redbear@vrx.net |
