It is currently Thu May 14, 2026 11:37 am
 Post subject: 62 Valiant parts search
PostPosted: Sun Sep 02, 2001 10:03 am
1. My son has acquired a 1962 Valiant 4-door, which he plans to use for a commuter (before anyone gets excited, the floor and the bottom of the dash were completely rusted out, so this is not collector's stock). Problem: it's got a shot rear axle bearing, and the 1962's used a peculiar and now discontinued bearing (bearing part #GRW206CCR). Anyone know where he could get one at less-than-unobtainium prices?
Do the rear axles from the 1963 or later Valiants interchange into the 1962? He may be able to score a '63 parts car for free.
2. Also, anyone know where to find a gas cap for a '62? They're also apparently an odd size (1-1/4"?), no longer listed by our local parts houses.
arbuch@sonic.net
PostPosted: Mon Sep 03, 2001 11:54 am
: the 1962's used a peculiar and now
: discontinued bearing (bearing part
: #GRW206CCR).
Interchange on that bearing (and SEAL!) is 1960-'62 Valiant and Lancer. Check with the places that advertise with the word "BEARINGS" under "Multi-Make Parts For Sale" in Hemmings.
: Do the rear axles from the 1963 or later
: Valiants interchange into the 1962?
The entire rear axle assembly will indeed swap in. If the '63 has a different ratio, which it may, the speedometer will be off; he'd want to swap the speedo drive pinion as well.
: 2. Also, anyone know where to find a gas cap
: for a '62?
Interchange is '60-'66 Valiant, Lancer, Barracuda, Dart. Stant G-27. They show up on Ebay with some frequency.
DS
redbear@vrx.net
