It is currently Sat Jun 13, 2026 2:25 am
PostPosted: Tue Dec 18, 2007 4:42 pm
Hi,
already searched for rotor removal but the search gave me distributor rotor results, can anybody guide me on how to remove the rotors from the spindles?
maybe a link if you have one.
thanks for the help.
'Sup
PostPosted: Tue Dec 18, 2007 6:13 pm
First you unbolt the calipers and support then so the hose isn't holding them up. Then it's time to get the rotors off, and that's actually pretty easy.
They're held on by a castelated nut hidden under the grease cap. You just need to remove the cotter pin holding the nut in place and unscrew the nut. Then you can pull the rotor straight off the spindle.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
