| Removing rotors from spindle https://slantsix.org/forum/viewtopic.php?t=26293 |
| Author: | chargerucd [ Tue Dec 18, 2007 4:42 pm ] |
| Post subject: | Removing rotors from spindle |
Hi, already searched for rotor removal but the search gave me distributor rotor results, can anybody guide me on how to remove the rotors from the spindles? maybe a link if you have one. thanks for the help. |
| Author: | Matt Cramer [ Tue Dec 18, 2007 6:13 pm ] |
First you unbolt the calipers and support then so the hose isn't holding them up. Then it's time to get the rotors off, and that's actually pretty easy. They're held on by a castelated nut hidden under the grease cap. You just need to remove the cotter pin holding the nut in place and unscrew the nut. Then you can pull the rotor straight off the spindle. |
