| Help - Grounding? https://slantsix.org/forum/viewtopic.php?t=26318 |
| Author: | bwhitejr [ Thu Dec 20, 2007 3:49 am ] |
| Post subject: | Help - Grounding? |
How is the dash physically grounded? Through the firewall? By a wire or by weld? The lights in the cab are very dim, but brighten up considerably when the engine is started. I also notice the lights behind the gauges are very weak. I suspect grounding issues. I will run separate wire to th e places that need them if I know all the places that might loose their ground over time and rust. TIA bwhitejr |
| Author: | Dart270 [ Thu Dec 20, 2007 7:14 am ] |
The dash is bolted, metal on metal (with some paint?) to the bulkheads above the door hinges, and via the pedal assembly to the firewall. Lou |
