It is currently Sun May 24, 2026 11:46 am
Post new topic  Reply to topic  [ 31 posts ]  Go to page 1 2 3 Next
PostPosted: Mon Dec 24, 2007 2:39 pm
The Pertronix instructions were pretty clear to me at first. Those of you familiar with the Ignitor II system know it comes with two wires attached: a red one, and a black one. The instructions direct me to connect the Ignitor black wire to the negative side of the ignition coil, and the red one to the positive side of the ignition coil. Is it really that simple? I remember when I put a Pertronix system on my 63 Fury 318, I had to splice into one of the wires going to the ballast resistor.
On the page following the above instructons were three diagrams labeled as follows:
1. Conventional points system with ballast resistor;
2. Ignitor system without ballast resistor; and
3. Ignitor system with ballast resistor.
There is absolutely no mention or description of the three diagrams in the text.
The only difference in this replacement as compared to that of the 63 Fury is that I purchased the Pertronic II coil also with this Ignitor. Anybody lend me some advice on this?
Thank you.
PostPosted: Mon Dec 24, 2007 3:57 pm
Here I sit red-faced. The instructions I was using came from the Pertronix website. They appear to be dated 12/01. The instructions coming with the Ignitor II kit were dated 05/01 AND they include some additional instructions. I will muddle through this and get it working without additional assistance. Again...I sit red faced.
PostPosted: Mon Dec 24, 2007 4:40 pm
I found the directions alittle confusing. Then again, I burned through 2 sets. I'm sticking with points for a bit
My Car Domain
PostPosted: Mon Dec 24, 2007 7:08 pm
I have a pertronix II on my car - no problems. - All I did was wire up the red and black wires to the coil as per the instructions - The Coil still has to have the + and - Wires connected to it from the vehicle's wiring harness.
I also Jumpered out the Ballast Resistor as per the instructions - Just unplug it and run a wire between the 2 terminals or 4 termainals if You have a 4 pin resistor. It should fire up and work - I have run mine like this for 2 years on the track and the street.
Best of luck - Greg
 Post subject: Pertronix Install II
PostPosted: Sun Dec 30, 2007 12:30 pm
Instructions accompanying the Ignitor II aren't really the best. Example, they tell me that while installing the magnet sleeve and rotor in the distributor, DO NOT REMOVE THE GREEN TAPE FROM THE MAGNET SLEEVE. I can't imagine that the tape is left on forever, but there aren't any instructions telling me to remove it later. What gives?[/b]
PostPosted: Mon Dec 31, 2007 4:57 am
And the answer is: you leave the green tape on.
PostPosted: Mon Dec 31, 2007 5:36 am
I think the Green tape holds the magents or triggers in place - Take it off and do go.'
 Post subject: Pertronics
PostPosted: Mon Dec 31, 2007 9:30 am
"Take it off and do - go?"
PostPosted: Mon Dec 31, 2007 9:47 am
Leave the tape on, or it will fall apart...
 Post subject: Pertronix Install Final
PostPosted: Tue Jan 01, 2008 8:51 am
Finished up the install awhile ago and I am happy to report the engine now responds quickly to throttle speed changes. Additionally, I can't believe how smoothly it runs. Thanks to all who posted on this.
PostPosted: Tue Jan 01, 2008 12:43 pm
Sorry - That should read take it off and no go.. Yes as in it'll fall apart.
PostPosted: Sat Apr 18, 2009 11:50 pm
Hi Greg,
I am thinking about buying the pertronix II for my '72 Valiant. You are running a Blaster II coil, right? and can you recommend where to buy the Pertronix II for my car? Thanks, Nico
PostPosted: Sun Apr 19, 2009 3:05 am
I got mine at JC Whitney:
Pertronix
Pertronix II
Danny
PostPosted: Sun Apr 19, 2009 3:17 am
Check ebay.
Should also be able to get free shipping..........
If it's an ebay store, the slant 6 may not be listed, so once you find one for a mopar, call them up and see if they have one for the slant 6. And ask for the same deal ($ and free shipping)
PostPosted: Sun Apr 19, 2009 6:23 am
Hi Greg,
Yep, I am running the MSD blaster II coil.. In black for the stock look of course.
The links etc. others provided should get the job done.
