valve stem seal size
https://slantsix.org/forum/viewtopic.php?t=26431
Author:  Roelof [ Fri Dec 28, 2007 10:57 pm ]
Post subject:  valve stem seal size
I'm rebuilding a 225 slant in a '73 Valiant. The valve stem seals that came with the gasket kit have two different sizes. Six small ones and six higher seals. Because the old seals were almost disappeared i do not know what seal should go on what valve.
I think that the high ones should go on the exhaust. Is that correct?
Roelof
Author:  Eric W [ Sat Dec 29, 2007 1:05 am ]
The small seal goes on the exhaust valve stem, the large on the intake.
Author:  Roelof [ Sat Dec 29, 2007 9:36 pm ]
Thank you,
Roelof
