It is currently Thu May 14, 2026 2:21 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
 Post subject: Distributor mods??
PostPosted: Thu Sep 06, 2001 9:01 am
Looking to build spark scatterer for warm street/mild strip action.(I know...that's a compromise)
I do plan on using the HEI conversion. Have '74 vintage electronic apart on bench. Looking for suggested mods to internals while I put it together, maybe diagrams/pics?
Went back and checked previous posts, found no. for adjustable vac. adv. Didn't find general concensus for streetable mods.
Roger
GTS225@aol.com
 Post subject: Re: Distributor mods??
PostPosted: Thu Sep 06, 2001 10:46 pm
: Looking to build spark scatterer for warm
: street/mild strip action.(I know...that's a
: compromise)
: I do plan on using the HEI conversion. Have '74
: vintage electronic apart on bench. Looking
: for suggested mods to internals while I put
: it together, maybe diagrams/pics?
: Went back and checked previous posts, found no.
: for adjustable vac. adv. Didn't find general
: concensus for streetable mods.
Ok...just for you...go to the link below.
Posted is a good set of distributor recurve instructions. The hardest thing is to get the primary (stock) light spring adjusted to start the mechanical advance right off idle. (find a good idle speed to work from)
Another issue is the "advance stop plate" or slotted plate the weights move in. Most performance SL6 timing curves need less mechanical advance (shorter slots) so you can run more initial timing and still keep the total around 28 to 32 degrees.
Dialing-in a good distributor advance curve takes a lot of trial and error time.
Distributor Advance Curve Adjustment.
PostPosted: Fri Sep 07, 2001 6:38 am
: Ok...just for you...go to the link below.
WOW!! Just for me ?!?! Now, the rest of you don't get to go to "my" link.....you'll have to get your own !! :-D
Seriously, Thanks, Doug !!
Roger
GTS225@aol.com
PostPosted: Sun Sep 23, 2001 12:17 pm
: Posted is a good set of distributor recurve
: instructions. The hardest thing is to get
: the primary (stock) light spring adjusted to
: start the mechanical advance right off idle.
: (find a good idle speed to work from)
: Another issue is the "advance stop
: plate" or slotted plate the weights
: move in. Most performance SL6 timing curves
: need less mechanical advance (shorter slots)
: so you can run more initial timing and still
: keep the total around 28 to 32 degrees.
: Dialing-in a good distributor advance curve
: takes a lot of trial and error time.
: DD
Who makes the distributor advance kit and what is the part number? That kit looks like just what I need.
Pete Vanderlaan
pmvdlaan@picusnet.com
PostPosted: Sun Sep 23, 2001 9:21 pm
: Who makes the distributor advance kit and what
: is the part number? That kit looks like just
: what I need.
: Thanks : Pete Vanderlaan
Crane Cams kit # 99604 (Electronic) & 99605 for Points.
I never saw much difference in the 2 kits, except for the instruction sheets.
