It is currently Wed Jun 03, 2026 9:05 pm
PostPosted: Mon Jan 07, 2008 9:25 am
Where do the copper washers go on the brake lines to the disk brake caliper? One on either side of the hose connection? Or both on one side?
TIA
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Mon Jan 07, 2008 9:43 am
They are gaskets. If you are speaking about the "banjo" hose connection, then they go on both sides. You need 2 for each caliper end connection.
FYI, a cheap-a$$ friend of mine tried to make washers out of copper pennies on a lathe and they did not seal - alloy was too hard.
PostPosted: Mon Jan 07, 2008 10:22 am
I had quite a collection of brake caliper hose washers since they came with both my rebuilt calipers and the new hoses. Do this with a few cars and one ends up with a lot of washers.
PostPosted: Tue Jan 08, 2008 10:59 am
You can buy sets of copper washers from Harbor Freight fairly cheaply. In a pinch I've carefully sanded the old washers very smooth and them reused them w/o problems.
