Hitch Plans needed
https://slantsix.org/forum/viewtopic.php?t=26532
Author:  68barracuda [ Sat Jan 05, 2008 7:25 am ]
Post subject:  Hitch Plans needed
Hi guys - I urgently need a set of plans for a tow hitch for a 68 Fastbody Barracuda
Regards
Fanie Gerber
Author:  Davids63Dart [ Sat Jan 05, 2008 9:19 am ]
I have an old hitch from my 63 Dart. I could give you some dimensions if they're the same.
Author:  68barracuda [ Sat Jan 05, 2008 10:00 am ]
Thank you Dave
A pic or two will also be appreciated if possible - it will give me somewhere to start
Fanie
Author:  Joshie225 [ Sat Jan 05, 2008 1:48 pm ]
Lots of cars and trucks have the same rear frame width as an A-body. I put a receiver hitch on my wife's '72 Duster back in '95. I had a shop weld it right to the subframe. The hole for the ball mount had to be moved from below the cross tube to behind it, but that's it.
If you're on a budget I would measure the subframe width and go hit a wrecking yard and see what matches up.
Author:  Davids63Dart [ Sat Jan 05, 2008 5:16 pm ]
Here's a pic with dimensions.
Author:  sandy in BC [ Sat Jan 05, 2008 5:28 pm ]
Nice photo work!
Author:  68barracuda [ Sat Jan 05, 2008 10:49 pm ]
Thanx
The big issue is that down here in South Africa the there is not many of these guys around anymore on the roads or in wrecking yards
Author:  Joshie225 [ Sat Jan 05, 2008 11:11 pm ]
True, but since there are many pickup trucks that have the same width frame rails they can donate a receiver hitch.
