It is currently Mon Nov 16, 2026 12:53 am
 Post subject: Hitch Plans needed
PostPosted: Sat Jan 05, 2008 7:25 am
Hi guys - I urgently need a set of plans for a tow hitch for a 68 Fastbody Barracuda
Regards
Fanie Gerber
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Sat Jan 05, 2008 9:19 am
I have an old hitch from my 63 Dart. I could give you some dimensions if they're the same.
1963 Dodge Dart -225 Slant 6, 904, 2.76's, 18.84 @ 73
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Sat Jan 05, 2008 10:00 am
Thank you Dave
A pic or two will also be appreciated if possible - it will give me somewhere to start
Fanie
Regards,
Fanie Gerber
PostPosted: Sat Jan 05, 2008 1:48 pm
Lots of cars and trucks have the same rear frame width as an A-body. I put a receiver hitch on my wife's '72 Duster back in '95. I had a shop weld it right to the subframe. The hole for the ball mount had to be moved from below the cross tube to behind it, but that's it.
If you're on a budget I would measure the subframe width and go hit a wrecking yard and see what matches up.
PostPosted: Sat Jan 05, 2008 5:16 pm
Here's a pic with dimensions.
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Sat Jan 05, 2008 5:28 pm
Nice photo work!
PostPosted: Sat Jan 05, 2008 10:49 pm
Thanx
The big issue is that down here in South Africa the there is not many of these guys around anymore on the roads or in wrecking yards
Regards,
Fanie Gerber
PostPosted: Sat Jan 05, 2008 11:11 pm
True, but since there are many pickup trucks that have the same width frame rails they can donate a receiver hitch.
