It is currently Wed Jun 17, 2026 8:06 am
 Post subject: vavle cover vent
PostPosted: Wed Jan 09, 2008 9:21 am
Car Model: 1968 A108 225/3 on the tree
is it critical that the vavle cover breather be run into the air cleaner?
i'm considering running it to the plug in mt #6 intake runner. does it help the engine to distribute the breater across all cylinders or not?
D~~~!
PostPosted: Wed Jan 09, 2008 10:04 am
The valve cover breather (air inlet) should be ducted to the air cleaner or vented directly to atmosphere. Do NOT run it to the intake tract, that would spoil everything. Your crankcase needs an air inlet (breather) and an air outlet (PCV valve and hose, which should be connected to the intake tract at a central location -- base of carb, new tap into the intake manifold's central plenum.)
 Post subject: ok
PostPosted: Wed Jan 09, 2008 10:28 am
Got it!
i thought the inward draw of the carb had the valve cover breather working as an exhaust, not an intake.
thank u!
my 1st car, a '62 falcon, always had a lot of fumes coming out of that hose. i always thought of it backwards i guess.
D~~~!
