| Finally done but...1 more "q" https://slantsix.org/forum/viewtopic.php?t=2668 |
| Author: | Alex [ Tue Sep 11, 2001 11:10 am ] |
| Post subject: | Finally done but...1 more "q" |
I finally got my 65 valiant v100 upgraded to a super six 2 barrel setup and it turns on and it idles. I haven't driven it yet though. When I try to accelerate, it bogs. Too much gas? Jets too big? If I accelereate the engine slow enough, it will rev up but only to a ceratin point, then it wants to turn off. Any ideas? Orionsax7@cs.com |
| Author: | Chuck Rivers [ Fri Oct 05, 2001 10:07 am ] |
| Post subject: | Re: Finally done but...1 more "q" |
: I finally got my 65 valiant v100 upgraded to a : super six 2 barrel setup and it turns on and : it idles. I haven't driven it yet though. : When I try to accelerate, it bogs. Too much : gas? Jets too big? If I accelereate the : engine slow enough, it will rev up but only : to a ceratin point, then it wants to turn : off. Any ideas? I upgraded my '63 to a Super Six with no problems, but I had taken the carb to a shop and had a professional rebuild done on it. I would first check to see that you are getting sufficient gas from the accelerator pump for the acceleration problem. For the second problem, I have seen a stall-out problem with a couple of old 1 bbl carbs that were shot. It could be a low float adjustment. I would guess that a full rebuild is in order. Chuck webmaster@omnipages.com |
