It is currently Mon Nov 23, 2026 5:47 am
 Post subject: flywheel for 11" clutch
PostPosted: Wed Jan 16, 2008 11:30 am
Car Model: 65 A100 truck
Hello,back in 75,we bought a B-100, 3 speed ,/6 van with the optional 11" HD clutch ,low mount starter and v8 BH adapter.Does any one know of a source for buying one of these flywheels ? cant seem to locate any, new or used.Thanks. .. Dee.
PostPosted: Wed Jan 16, 2008 3:03 pm
Well, I consider you lucky. You should be able to just buy a SB V8 flywheel (check ring gear tooth count when you order) and oval out one of the holes to the crank and you should be good to go.
 Post subject: i have one
PostPosted: Wed Jan 16, 2008 5:05 pm
Hello,
I posted this a few times, but yeh, I have the flywheel to get rid of. It is for a small hub crank...what diam crank hub have you got? It was on my '64 D100. I already gave away the clutch, pressure plate and TOB though.
PM me if interested, cheap.
rock
'64D100
 Post subject: Thanks for the replies.
PostPosted: Wed Jan 16, 2008 10:00 pm
Unfortunately I have a 1980 big hub engine.I guess I would have to alter the spacer bolt pattern also, in order to use a 318 wheel .Hmmm.. thanks for the ideas.
PostPosted: Thu Jan 17, 2008 10:38 am
I've got a large hub 11" flywheel. You can have it for the price of shipping.
Franklin
'61 Valiant
PostPosted: Tue Jan 29, 2008 8:37 pm
Unfortunatly we live at opposite ends of the continent.This whole exersise is to repower a 91Ford f350 car hauler, the 7.3 diesel dropped a valve and cant justify the repair cost .This truck only gets used a few times a year.I have a /6 727 combo out of my old 7500lbs( 10k with trailer) p200 work truck,the thing gave me 9 years of trouble free service, should have a few more left in it...lol ..plus the look on Ford owners faces should be a hoot... Thanks.. Dee.
PostPosted: Wed Jan 30, 2008 6:49 am
How soon do you need it?...I have a big hub flywheel from a 76 1 ton.
The trick is its under feet of snow.....
Users browsing this forum: No registered users and 14 guests
