It is currently Wed May 20, 2026 2:29 pm
PostPosted: Sat Sep 15, 2001 2:42 pm
The slant 6 from my 68 dart is in the machine shop with a spun bearing, worn head and rockers. I also have another slant 6 in the garage. I know that later years came with hardened valve seats and no spark plug tubes(?). Are there other diffrences? Would a later head be preferable to an earlier one?
I dont know what year the motor in my garage is. It has black valve covers with a "902" sticker. A carb with alot of wires and stuff on it( for emmissions?). Also a 5 blade fan and on the intake manifod it says no more than 10 ft lbs on the bolts or you will screw it up. Can someone give me a guess as to the year? Would the head bolt to a 68 block?
Thanks in advance
Byron
scspence71@aol.com
PostPosted: Sat Sep 15, 2001 8:40 pm
Take the valve cover off and see if the rockers have adjustable rocker arms. If they dont then its prob a 1981 or NEWER motor.
If its a 1980 or OLDER i would use the head on your new motor if its in good shape...
: The slant 6 from my 68 dart is in the machine
: shop with a spun bearing, worn head and
: rockers. I also have another slant 6 in the
: garage. I know that later years came with
: hardened valve seats and no spark plug
: tubes(?). Are there other diffrences? Would
: a later head be preferable to an earlier
: one?
: I dont know what year the motor in my garage
: is. It has black valve covers with a
: "902" sticker. A carb with alot of
: wires and stuff on it( for emmissions?).
: Also a 5 blade fan and on the intake manifod
: it says no more than 10 ft lbs on the bolts
: or you will screw it up. Can someone give me
: a guess as to the year? Would the head bolt
: to a 68 block?
: Thanks in advance
: Byron
http://hackme.dhs.org:8080
cralt@hackme.dhs.org
PostPosted: Sat Sep 15, 2001 10:41 pm
Looks like they arent adjustable rockers. Can i use hydraulic lifters in my motor? Would i have to to use the head? Are there any design difrences that would make a later head more desireable, besides hard seats.
I took the head off, it looks good except the water passages. Can these be cleaned up at the machine shop?
Byron
P.S. my 68 head is toast(needs alot of work).
: Take the valve cover off and see if the rockers
: have adjustable rocker arms. If they dont
: then its prob a 1981 or NEWER motor.
: If its a 1980 or OLDER i would use the head on
: your new motor if its in good shape...
Scspence71@aol.com
