| Motor Identification/Buildup https://slantsix.org/forum/viewtopic.php?t=2680 |
| Author: | Byron [ Sat Sep 15, 2001 2:42 pm ] |
| Post subject: | Motor Identification/Buildup |
The slant 6 from my 68 dart is in the machine shop with a spun bearing, worn head and rockers. I also have another slant 6 in the garage. I know that later years came with hardened valve seats and no spark plug tubes(?). Are there other diffrences? Would a later head be preferable to an earlier one? I dont know what year the motor in my garage is. It has black valve covers with a "902" sticker. A carb with alot of wires and stuff on it( for emmissions?). Also a 5 blade fan and on the intake manifod it says no more than 10 ft lbs on the bolts or you will screw it up. Can someone give me a guess as to the year? Would the head bolt to a 68 block? Thanks in advance Byron scspence71@aol.com |
| Author: | CrAlt [ Sat Sep 15, 2001 8:40 pm ] |
| Post subject: | Re: Motor Identification/Buildup |
Take the valve cover off and see if the rockers have adjustable rocker arms. If they dont then its prob a 1981 or NEWER motor. If its a 1980 or OLDER i would use the head on your new motor if its in good shape... Quote:
: : The slant 6 from my 68 dart is in the machine : shop with a spun bearing, worn head and : rockers. I also have another slant 6 in the : garage. I know that later years came with : hardened valve seats and no spark plug : tubes(?). Are there other diffrences? Would : a later head be preferable to an earlier : one? : : I dont know what year the motor in my garage : is. It has black valve covers with a : "902" sticker. A carb with alot of : wires and stuff on it( for emmissions?). : Also a 5 blade fan and on the intake manifod : it says no more than 10 ft lbs on the bolts : or you will screw it up. Can someone give me : a guess as to the year? Would the head bolt : to a 68 block? : Thanks in advance : Byron http://hackme.dhs.org:8080 cralt@hackme.dhs.org |
| Author: | Byron [ Sat Sep 15, 2001 10:41 pm ] |
Looks like they arent adjustable rockers. Can i use hydraulic lifters in my motor? Would i have to to use the head? Are there any design difrences that would make a later head more desireable, besides hard seats. I took the head off, it looks good except the water passages. Can these be cleaned up at the machine shop? Thanks Byron P.S. my 68 head is toast(needs alot of work). Quote:
: : Take the valve cover off and see if the rockers : have adjustable rocker arms. If they dont : then its prob a 1981 or NEWER motor. : : If its a 1980 or OLDER i would use the head on : your new motor if its in good shape... Scspence71@aol.com |
