It is currently Fri May 22, 2026 9:09 am
 Post subject: Gauge Question
PostPosted: Thu Jan 24, 2008 4:40 pm
Hi, im a new member and i have a question about my gauges. I have no dash lights and my gas gauge and temp gauge dont work eihter. Im thinking its the instrument voltage regulator. What do you guys think? Also where can i get a new one , or is there any thing i can do to fix this one? Its in a 74 dart. Thanks
PostPosted: Fri Jan 25, 2008 10:02 am
No dash lights have anything to do with the voltage limiter except for sharing a ground path - most likely you've lost grounding to the dash.
You can use a test light to test for that easily; ground the light well and test it against the fuse box; then turn on the lights and touch it to the headlight knob nut - if the dash lights and test light come on (maybe dimly), you're sure it's a bad ground.
PostPosted: Fri Jan 25, 2008 2:01 pm
For a few dollars in parts you can build your own modern electronic voltage limiter to replace the original mechanical voltage limiter:
http://www.allpar.com/history/mopar/electrical2.html
http://www.earlycuda.org/tech/gauge-convert.htm
http://www.slantsix.org/forum/viewtopic ... 965#134448
Or you can buy one already made here:
http://www.demonivr.com/index.html
 Post subject: Gauges
PostPosted: Fri Jan 25, 2008 5:29 pm
I checked to see if the headlight switch was grounded with my power probe. It is and the dashlights did not come on. Guess i must have to seperate problems. Think i might have to pull out the cluster and see if i see anything wrong. Thanks for the help.
74 2 door dart. All stock, work in progress!
PostPosted: Fri Jan 25, 2008 7:38 pm
When you disconnect the plug from the back of the cluster be sure to pull straight.
Do not work it back and forth side to side as this will damage the pins.
PostPosted: Sat Jan 26, 2008 11:29 am
Make sure you check the fuses .
81 Dodge D150
It looked easier in the book .
PostPosted: Sat Jan 26, 2008 4:08 pm
Already checked all the fuses. Still thinking it has to do with the IVR. Will have to pull the cluster and have a look. Thanks
PostPosted: Sun Jan 27, 2008 10:56 am
Dudley,
I have the same problem with my fuel/temp gauges, and I read the Allpar article. Is the voltage limiter on the back of the gauge cluster only for early 60s cars? I have a 71 dart, is my voltage limiter located in the same place?
PostPosted: Sun Jan 27, 2008 11:00 am
Yes, on the back of the cluster.
PostPosted: Fri Feb 22, 2008 4:38 pm
Site Admin
Two different problems unless you have a bad ground on the cluster. The IVR has nothing to do with the dash lights.
Chuck Rivers, Webmaster
Image Image Image Image
