It is currently Mon Nov 23, 2026 8:51 am
 Post subject: Hybrid Clutch?
PostPosted: Thu Jan 24, 2008 9:08 pm
Paging through my new Speedway catalog last night and I came across some small multi-disk setups that bolts to a flexplate (similar to newer Neon/PT setups?). Got me to thinking about my situation with McLoed dropping the SFI flywheel I need.
Anybody looked at these setups? I know the ones Speedway has are pretty much race only (not recommended to drive the car onto the trailer :) ), but are there others setups that might work? If memory serves, one was a Zoom clutch, and I know they sell a street multi-disk setups, so maybe the disks could be swapped?
BTW, they were like $400, w/ the flexplate.
Any chance one could be swapped onto a Mopar flexplate? Can you even get an SFI flexplate for a /6?
Just thought I would throw it out there.
'15 Chrysler 200S V6
'74 Duster 360, factory 4 speed car
PostPosted: Thu Jan 24, 2008 10:16 pm
Can you even get a flexplate for a slant that has a ring gear?
PostPosted: Fri Jan 25, 2008 8:04 am
Never thougth about that. Dang.
Grasping for strings, I guess.
PostPosted: Fri Jan 25, 2008 11:16 am
Cameron Tilley had a couple of special ring gears on flex plates made up to run quartermaster clutches like the ones you describe. Tried to sell one on Ebay to no avail. I may try this. He will have one behind his next Slant roadrace setup.
PostPosted: Fri Jan 25, 2008 1:07 pm
I may try this.
How? Are you going to have a special one made as well, or buy one from Cameron?
Any details on where he got his?
Any left? :)
PostPosted: Fri Jan 25, 2008 4:36 pm
Seems like someone might have mentioned this already, but I guess Wilcap will do custom flywheels.
They list a 273 flywheel with a 122 tooth ring gear for $275 in steel and $350 in Aluminum.
Shouldn't be hard to get them to move the one bolt that is off and make it work with a /6.
The standard one is listed with pressure plate patterns for 9 1/8", 9 1/4" and 9.5" B&B and Diaphragm clutches, don't know about the 10" I was looking to run.
Not sure about SFI approval, either.
PostPosted: Sat Jan 26, 2008 5:41 am
Thanks for the Wilcap info. That one will definitely work with one hole moved and having different PP bolt patterns would be great.
EDIT - they actually list the Slant 6 just below the other V8s... 10" bolt pattern should be OK for certain 10" PPs.
Cameron has a super CNC guy down there - real artist. Think he made two and would likely sell one and/or make more. The clutch/PP and ring/flexplate weighs <20lbs altogether, IIRC.
Check this: http://tilleyracing.com.au/product-engine.php
Users browsing this forum: Google [Bot] and 6 guests
