| Hybrid Clutch? https://slantsix.org/forum/viewtopic.php?t=26840 |
| Author: | DionR [ Thu Jan 24, 2008 9:08 pm ] |
| Post subject: | Hybrid Clutch? |
Paging through my new Speedway catalog last night and I came across some small multi-disk setups that bolts to a flexplate (similar to newer Neon/PT setups?). Got me to thinking about my situation with McLoed dropping the SFI flywheel I need. Anybody looked at these setups? I know the ones Speedway has are pretty much race only (not recommended to drive the car onto the trailer BTW, they were like $400, w/ the flexplate. Any chance one could be swapped onto a Mopar flexplate? Can you even get an SFI flexplate for a /6? Just thought I would throw it out there. |
| Author: | Joshie225 [ Thu Jan 24, 2008 10:16 pm ] |
Can you even get a flexplate for a slant that has a ring gear? |
| Author: | DionR [ Fri Jan 25, 2008 8:04 am ] |
Quote: Can you even get a flexplate for a slant that has a ring gear?
Never thougth about that. Dang.Grasping for strings, I guess. |
| Author: | Dart270 [ Fri Jan 25, 2008 11:16 am ] |
Cameron Tilley had a couple of special ring gears on flex plates made up to run quartermaster clutches like the ones you describe. Tried to sell one on Ebay to no avail. I may try this. He will have one behind his next Slant roadrace setup. Lou |
| Author: | DionR [ Fri Jan 25, 2008 1:07 pm ] |
Quote: I may try this.
How? Are you going to have a special one made as well, or buy one from Cameron?Lou Any details on where he got his? Any left? |
| Author: | DionR [ Fri Jan 25, 2008 4:36 pm ] |
Seems like someone might have mentioned this already, but I guess Wilcap will do custom flywheels. They list a 273 flywheel with a 122 tooth ring gear for $275 in steel and $350 in Aluminum. Shouldn't be hard to get them to move the one bolt that is off and make it work with a /6. The standard one is listed with pressure plate patterns for 9 1/8", 9 1/4" and 9.5" B&B and Diaphragm clutches, don't know about the 10" I was looking to run. Not sure about SFI approval, either. |
| Author: | Dart270 [ Sat Jan 26, 2008 5:41 am ] |
Thanks for the Wilcap info. That one will definitely work with one hole moved and having different PP bolt patterns would be great. EDIT - they actually list the Slant 6 just below the other V8s... 10" bolt pattern should be OK for certain 10" PPs. Cameron has a super CNC guy down there - real artist. Think he made two and would likely sell one and/or make more. The clutch/PP and ring/flexplate weighs <20lbs altogether, IIRC. Check this: http://tilleyracing.com.au/product-engine.php Lou |
