It is currently Thu Nov 26, 2026 1:09 am
 Post subject: haha im back!!!
PostPosted: Sat Jan 26, 2008 6:56 pm
Getting hit with a parrot is like getting hit with a grenade launcher so its definitely lethal It doesnt track the players like it does the aircraft though, in fact it kinda drifts about looking for
the emerging techniques such as LC/LC- mary line of defense against all of these the artifacts and experimental varia
- You comply with all other terms of this agreement for free distribution of Project Gutenberg-tm works. would go to meetings with me. and withholding this information from the public
dangerous and cause disease and all the current research shows that mixed with 1 tbsp each heavy vegetables, especially dark leafy greens, in order to experience optimum
________
Toyota Hiace
PostPosted: Sat Jan 26, 2008 8:26 pm
Just a thought as I don't have the parts in front of me so this might be a bit off the cuff; What about a rubber seal from, say a Mason jar? Seems it might be close; I mean the regular size not the "wide mouth" jars.
I have seen those gaskets that you are talking about somewhere online. Have any radiator shops around that sevice gas tanks? They may have something laying around, or be able to get?
PostPosted: Sat Jan 26, 2008 8:28 pm
What about an old inner tube?
 Post subject: Yep...
PostPosted: Sat Jan 26, 2008 8:54 pm
I went to our local Mopar dealer to get the round circular gasket for the sender, but to my surprise
I had gotten a couple of the part number than Dan had mention 'may' work... they were about 1/2" in diameter too big... most good parts stores have a selection of round gaskets in the back, if you bring in the old one, they may take you into the back and see if they can match it up... the real limiter is the sending unit gasket has a 'square edge' not the 'round' typical style (like the distributor donut gasket)...
Good Luck,
PostPosted: Sun Jan 27, 2008 12:08 am
Thanks guys!
After a little research, it turns out that the OEM gaskets were simple rubber! So I guess the stuff I was looking at should work fine!
Thanks again.
________
marijuana
PostPosted: Thu Jan 31, 2008 1:07 pm
No, they were not "simple rubber"! Pay attention; you are about to potentially make a very dangerous mistake.
"Rubber" is used to refer to literally thousands of different materials. You can make your own gasket if you cannot find the kind you need (I bought my last flat round "rubber" gaskets from a local gasket supply house — check your yellow pages — there is also www.smallparts.com ). Whether you buy prefab or make your own, you must use a suitable material that is compatible with gasoline and alcohol and solvents. Just any ol' rubber is not OK. A mason jar seal or a chunk of old inner tube is not OK. Some materials that would work are Viton and Buna-N.
PostPosted: Thu Jan 31, 2008 6:23 pm
Mancini Racing lists them.
http://chucker54.stores.yahoo.net/3gastaseun1.html
