It is currently Mon Jun 01, 2026 2:50 am
PostPosted: Tue Jan 29, 2008 4:00 pm
I want to swap a K/H setup onto my '72. I have only wrenched on drums and '73 discs so far, so I've never seen a K/H setup up close and personal. My parts car is across town and I can't go look at it tonite but I finally put $ in the bank so I can use my visa debit to purchase parts online.
My question/ problem: on rockauto the '72 340cid demon parts list doesn't include a front hose like I used on my '73 caliper- one end to take a brake line fitting and clip into the bracket, and one end to take a banjo bolt and copper washer into the caliper body. The hoses I'm seeing for '72 are double female. Does the K/H take a short hard line inbetween the rubber hose and the caliper? Or am I looking in the wrong place?
Kevin
in philly
madam im adam
PostPosted: Tue Jan 29, 2008 6:16 pm
The K-H's take the hose with the double female ends.
PostPosted: Tue Jan 29, 2008 7:18 pm
they use the same hose as the drum brakes. yes they do have a short hard line from the hose to the caliper just like the drum uses a short hard line form the hose to the slave. the disc brakes changed in 73. make sure you get a proportioning valve also, factory or aftermarket. basicly, swapping the spindle and everything on it is all you have to do.
zedpapa
soon to have 5 gears!!!
 Post subject: thanks fellas
PostPosted: Wed Jan 30, 2008 6:22 am
now I can collect parts with confidence and do the job in one sitting.
madam im adam
