It is currently Wed Nov 18, 2026 6:07 am
PostPosted: Wed Feb 06, 2008 11:11 am
Hi,
I would like to know your oppinion about my transmission, because I think that it is not working right.
When I drive fast with the gas pedal to the end, the engine push a lot and the transmission works perfectly, very soft. You can not heard or feel anything while the gearbox go up one to other gear.
... but when I drive soft, for any reason, you can heard and feel a noise and a pull.
Is it something wrong?
Why is not the same when I drive fast than when I drive soft?
Hola,
Quisiera saber su opinión sobre mi transmisión, porque creo que no está trabajando bien.
Cuando conduzco rápido pisando el celerador a fondo, el motor empuja mucho y la transmision trabaja perfectamente, no se escuchan ruidos ni se siente nada mientras la caja de cambios pasa de una marcha a otra.
... pero cuando conduzco suave, por algún motivo, se puede oir un ruido y sentir un tiron cuando cambia y sube a otra marcha.
¿está algo mal?
¿porqué el cambio es suave conduciendo rápido y no cuando conduzco despacio?
PostPosted: Wed Feb 06, 2008 11:15 am
It sounds like your transmission kickdown linkage (between the carburetor throttle and the transmission) probably needs adjusting. Do you have a service book for your car?
PostPosted: Wed Feb 06, 2008 11:17 am
:cry:
NO.
How can I adjust it?
PostPosted: Wed Feb 06, 2008 11:42 am
Does your car have the 1-barrel or 2-barrel carburetor?
PostPosted: Wed Feb 06, 2008 2:58 pm
It is a Carter BBD 4300S 2bbl like this ...
PostPosted: Mon Feb 18, 2008 4:07 pm
from what they have said here, the linkage kick down is only adjustable on the trans with the SS6 setup.
1976 Plymouth Feather Duster
2002 Dodge Dakota 4.7l v8
PostPosted: Mon Feb 25, 2008 8:02 am
:shock:
What´s that?
How can I adjust the transmission to work softer?
Another detail: I need to go up to 2700rpm (at least) to change the gear even when I drive soft.
How can I adjust the RPM to change up and down?
... de los que tengo, este es el que más gusta a mis hermanos:
PostPosted: Mon Feb 25, 2008 9:07 am
Click here to see how to adjust your kickdown linkage
