It is currently Sat Jun 13, 2026 12:14 pm
 Post subject: oil pan question
PostPosted: Wed Feb 06, 2008 4:33 pm
OK, so today I got the 68 225 out of the Coronet, and into the engine compartment of the 62 Valiant. It looks like the oil pan hump id to far forward to drop into the right spot......I have a engine from a 63 valiant if I need to swap pans......does anyone know for sure if I will need to swap pans? I had to clean up to get my wife......so I didnt have time to locate the trans into place to see if it needs to go back further..but I did have the head really close to the fire wall.
Thanks.....Andrew/Kidd
Wife's: 64 Valiant
My: 70 Road Runner, 67 Barracuda, AND the 62 Valiant drag car!!
PostPosted: Wed Feb 06, 2008 4:55 pm
Yes, you need a 60 - 66 oil pan and pick-up tube.
The sump on a 67 -76 pan is to far forward.
The only other pan that can be made to work is the 77 and up F-Body "small sump" pan but that one needs some dents to clear the steering's center link.
PostPosted: Wed Feb 06, 2008 5:43 pm
Thanks Doug.....so I guess I will get to change that gasket after all.
Andrew
Wife's: 64 Valiant
PostPosted: Wed Feb 06, 2008 7:52 pm
What a pan in the butt,didnt know there were that many different ones,Mark
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
