It is currently Sun May 17, 2026 2:51 pm
 Post subject: very soft shifting
PostPosted: Fri Feb 08, 2008 1:08 pm
Just changed to a super six setup. put in all the proper linkage, kickdown lever is all the way forward at idle but, now I seem to be have a shift problem.
used to hit pretty hard at slower speeds or, down shifts.
Now very quick and, soft shifting.
Plz. advise
PostPosted: Fri Feb 08, 2008 1:37 pm
One way or another, your kickdown linkage is improperly installed and/or adjusted too short.
PostPosted: Fri Feb 08, 2008 8:05 pm
what if the throw is too short to go all the way forward and, all the way back. which is more important? forward or, back?
went in a dart .... came from a volare' wagon.
plz advice
PostPosted: Fri Feb 08, 2008 8:54 pm
If that's the case, something's not installed properly and/or some components are not correct.
PostPosted: Fri Feb 15, 2008 1:12 am
you need to adjust the kickdown so the valve on the tranny opens all the way when WOT. sounds like you might have it set to downshift a lot later so you dont feel that"hard shift" torque. but i could be wrong, i had to fiddle wit mine till i got it to downshift right. i almost wish these trannies were vacuum, not linkage kick, but its nice to adjust.
PostPosted: Fri Feb 15, 2008 6:19 am
That's actually not the specified adjustment procedure. Doing it that way will probably change the shifting behaviour, and sometimes by chance and luck you can get shifts you can live with, but if the trans doesn't respond properly to the correct adjustment procedure, usually it means something's wrong with the linkage assembly, and/or not all the correct pieces are in use.
Pfft. GM junk.
PostPosted: Fri Feb 15, 2008 6:21 am
My bet is that the kickdown is misadjusted at the transmission. The 1-bbl kickdown can be adjusted under the hood. The super six kickdown is adjusted at the transmission.
Crawl under the car, pull the kickdown lever on the transmission all the way back, and loosen the adjuster hold down bolt on the tranny lever. At the same time, have someone under the hood pull the throttle on the carb all the way open and hold. Make sure the kickdown lever on the tranny is all the way back. Retighten the kickdown lever at the tranny. Take it for a drive.
Good luck!
vm
