It is currently Fri Nov 27, 2026 1:05 am
 Post subject: starter trouble
PostPosted: Tue Feb 12, 2008 10:31 pm
I have a chevy blazer that is having starting issues. When you try to start it the starter turns the motor over for just a second then you can hear the starter motor still running under not load. when it sounds like its not under a load it not longer turns the engine.. What I am wondering if this is a bendix problem or a ignition switch problem. anyone have any issues like this with a starter? IF so how did you fix it?
PostPosted: Tue Feb 12, 2008 11:06 pm
that would be an improvement - a Chev with a SLANT in it. :P
Fishin Rod :roll:
PostPosted: Wed Feb 13, 2008 3:37 am
It sounds like a bendix problem to me as well. My Suburbans have gone through starters that way. It sounds to me like you need to replace the starter.
PostPosted: Wed Feb 13, 2008 6:37 am
A solenoid mounted on the starter shoves the gear out on some of those. If you have a starter/alternator rebuilder close, I’d have it checked. I don’t know if the starter comes with a solenoid and the solenoid may
be all that you need.
PostPosted: Wed Feb 13, 2008 7:44 am
On My 73 Blazer it was all in the same case. I used to carry a small hammer and tap the solinoid with the handle when it stuck. It worked for a month til I could afford a new one.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Feb 13, 2008 10:31 am
If the starter keeps running with the key all the way to the right, then it might be a bad ballast resister assuming Blazers have such. If so, confirm by bypassing the ballast resister with a jumper. I've done this a couple of times with my Darts.
PostPosted: Wed Feb 13, 2008 10:36 am
Uh...no, definitely not.
Not only does the subject vehicle not have a ballast resistor, but this is not the symptom of a dead ballast resistor even if it did have one. A dead ballast resistor gives "cranks, fires, won't keep running when the key is released from 'start' to 'run'" symptoms.
PostPosted: Sat Feb 16, 2008 10:12 pm
I got a hold of the manual. The manual said that the starter had a clutch in it and would not turn the engine when it was bad. I got a new starter in it. The problem is fixed.
