It is currently Sun May 17, 2026 12:22 pm
 Post subject: replacing rear main seal
PostPosted: Wed Oct 03, 2001 10:14 am
Replacing it in the car will be a real P.I.T.A. to say the least. I did it once on a small block, and it wasn't too bad, but the /6 seal is up in the block more. I'm assembling my new "Screamin' Six" motor, and just put the rear main together yesterday. Lots of gaps the gaskets don't cover. Used lots of blue RTV.
PostPosted: Wed Oct 03, 2001 12:17 pm
: Replacing it in the car will be a real P.I.T.A.
: to say the least. I did it once on a small
: block, and it wasn't too bad, but the /6
: seal is up in the block more. I'm assembling
: my new "Screamin' Six" motor, and
: just put the rear main together yesterday.
: Lots of gaps the gaskets don't cover. Used
: lots of blue RTV.
The oil pan comes right off of my Dodge truck. Can I use a rope type seal? I'd hate to have to pull the crank. now that would be a pain! Thanks
Shearnstable@earthlink.net
PostPosted: Thu Oct 04, 2001 11:30 am
When I replaced the rear main seal on my A100 I dropped the oil pan and then took a small piece of wood dowel that was smaller than the rear main seal - and I tapped the upper part of the seal and away it went - it spun down to the point that I was able to grab it and spin it the rest of the way out. The new one spun right on it too! Make sure you put the new one on facing the correct way though - that's why I had to change mine in the first place - the previous one was on backwards.
Haven't had a leak out of it since.
Good luck,
Dan
gramma@dm-tech.net
