It is currently Thu May 28, 2026 7:43 am
 Post subject: shock brackets
PostPosted: Mon Feb 18, 2008 7:13 pm
Are the shock mounts on an 8 1/4" rear interchangeable with those on a 7 1/4" rear? The ones on my new 8 1/4" have the studs busted off, so They're NFG to me.
Thanks in advance,
Nat
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
 Post subject: Nope...
PostPosted: Mon Feb 18, 2008 7:19 pm
I just had a set of each of these in my hands while cleaning up my shed, and the answer is no, the 7.25" is a bit skinny compared to the 8.25"... the proper shock plates are interchangeable with the 8.75" rear...
PostPosted: Tue Feb 19, 2008 3:37 am
DI is correct. The 7 1/4 uses 2 1/2" axle tubes but the 8 1/4 and 8 3/4 use 3" axle tubes.
PostPosted: Tue Feb 19, 2008 7:01 am
Aside from the junkyard, where can I get a new set for my 8 1/4 rear? I'm having the same problem finding these parts as I am with the parking brake lever and strut.
Thanks for your replies,
Nat
