| shock brackets https://slantsix.org/forum/viewtopic.php?t=27272 |
| Author: | NewSlanter [ Mon Feb 18, 2008 7:13 pm ] |
| Post subject: | shock brackets |
Are the shock mounts on an 8 1/4" rear interchangeable with those on a 7 1/4" rear? The ones on my new 8 1/4" have the studs busted off, so They're NFG to me. Thanks in advance, Nat |
| Author: | DusterIdiot [ Mon Feb 18, 2008 7:19 pm ] |
| Post subject: | Nope... |
Quote: Are the shock mounts on an 8 1/4" rear interchangeable with those on a 7 1/4" rear? ]I just had a set of each of these in my hands while cleaning up my shed, and the answer is no, the 7.25" is a bit skinny compared to the 8.25"... the proper shock plates are interchangeable with the 8.75" rear... -D.Idiot |
| Author: | 70valiant [ Tue Feb 19, 2008 3:37 am ] |
DI is correct. The 7 1/4 uses 2 1/2" axle tubes but the 8 1/4 and 8 3/4 use 3" axle tubes. |
| Author: | NewSlanter [ Tue Feb 19, 2008 7:01 am ] |
Aside from the junkyard, where can I get a new set for my 8 1/4 rear? I'm having the same problem finding these parts as I am with the parking brake lever and strut. Thanks for your replies, Nat |
