It is currently Sat May 16, 2026 7:26 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 9 posts ]
PostPosted: Wed Oct 03, 2001 8:09 pm
Hey guys my 833od just gernaded tonight so I called up that castlemain Rodshop.- He said he had the kit in stock-includes adapter plate, thrust adapter ring and pilot bushing.- So i said what the heck i want to have my my cake and eat it too.. My car is a 74 dart swinger it weighs 3450# w/me in it. It run's 16.6 at 83mph. I have a 225 w/offy 4bbl 600 edelbrock, isky 265/465 cam, head milled .060 and mp performance valve springs. od 833 and 3.91 sure grip 8 1/4. hopefully the extra gear will help ;) Next up after this will be a ported cylinder head- 15's here I come....
Slantsix_@excite.com
PostPosted: Thu Oct 04, 2001 6:10 am
hey dan,
do you have a rooted/dummy block lying around?? it would pay to check all the machining has been done properly before fitting it.
theres been the occasional case where people have ordered kits (ive only heard of it in supra conversions, but you never know) and the drillings off, or something like that.
Mr_Mopar_Man@hotmail.com
PostPosted: Thu Oct 04, 2001 11:00 am
I have a block bellhousing and t-5 all lying around to mockup... my only concern is I must find a 240mm (9.5 inch) long input shaft.- I don't know what application these were found in? (Any ideas)-He said Buick??? The t-5 I have lying around is out of an s-10 pickup. So we'll see what is left to do when it arrives... I'll keep you guys posted...thanks for the support
PostPosted: Thu Oct 04, 2001 12:13 pm
: I have a block bellhousing and t-5 all lying
: around to mockup... my only concern is I
: must find a 240mm (9.5 inch) long input
: shaft.- I don't know what application these
: were found in? (Any ideas)-He said Buick???
: The t-5 I have lying around is out of an
: s-10 pickup. So we'll see what is left to do
: when it arrives... I'll keep you guys
: posted...thanks for the support
Word is that you can use the 5.0 & S-10 unit if you make and install a input shaft "nose" extension piece.
I am told that the clutch disc splines are in the correct position for a Mopar conversion but the input shaft tip is shorter and made for a smaller pilot bushing. This can be resolved by a machined extension with the added length and OD for the Mopar pilot, combined with an ID to press-onto the current T-5's tip. (make it .002-.004 undersize and then heat expand it befor pressing it on)
This all makes sense and should work fine as long as everything spins "ture" when finished. ( there is no real load on this section of the shaft, it's just for location / support)
If someone out there has the "lay-out" or measurments on this special tip, let us know.
PostPosted: Thu Oct 04, 2001 6:10 pm
keep us posted. I want to do the same thing to
my cars. I'm working with a couple Mustang 5.0 T5s. You should be able to measure the spigot/pilot adapter so it can be reproduced. I think the 5.0 shaft is about an inch shorter than the 833.
: Hey guys my 833od just gernaded tonight so I
: called up that castlemain Rodshop.- He said
: he had the kit in stock-includes adapter
: plate, thrust adapter ring and pilot
: bushing.- So i said what the heck i want to
: have my my cake and eat it too.. My car is a
: 74 dart swinger it weighs 3450# w/me in it.
: It run's 16.6 at 83mph. I have a 225 w/offy
: 4bbl 600 edelbrock, isky 265/465 cam, head
: milled .060 and mp performance valve
: springs. od 833 and 3.91 sure grip 8 1/4.
: hopefully the extra gear will help ;) Next
: up after this will be a ported cylinder
: head- 15's here I come....
tkeith@mindspring.com
PostPosted: Fri Oct 05, 2001 12:00 pm
: keep us posted. I want to do the same thing to
: my cars. I'm working with a couple Mustang 5.0
: T5s. You should be able to measure the
: spigot/pilot adapter so it can be
: reproduced. I think the 5.0 shaft is about
: an inch shorter than the 833.
What was the cost of the kit? I talked to them some time ago and they said that if someone was to order 10 of the kits that there would be a major price break. I'm not sure what major is? He said the kit cost $350 Aussie, but I don't know what that is in US. Maybe there is enough folks out there to join together and get the discount?
Rick
rcovalt@innernet.net
PostPosted: Fri Oct 05, 2001 3:51 pm
I was told that the kit cost $250 Australian and that the 9 1/2" input shaft is common to GM (Buick) V6s.
I think the major component is a bearing adapter which extends the snout. We could probably measure this part, it might be economical to have a machine shop make up a batch.
The
: What was the cost of the kit? I talked to them
: some time ago and they said that if someone
: was to order 10 of the kits that there would
: be a major price break. I'm not sure what
: major is? He said the kit cost $350 Aussie,
: but I don't know what that is in US. Maybe
: there is enough folks out there to join
: together and get the discount?
: Rick
PostPosted: Fri Oct 05, 2001 4:37 pm
: Word is that you can use the 5.0 & S-10
: unit if you make and install a input shaft
: "nose" extension piece.
: I am told that the clutch disc splines are in
: the correct position for a Mopar conversion
: but the input shaft tip is shorter and made
: for a smaller pilot bushing. This can be
: resolved by a machined extension with the
: added length and OD for the Mopar pilot,
: combined with an ID to press-onto the
: current T-5's tip. (make it .002-.004
: undersize and then heat expand it befor
: pressing it on)
: This all makes sense and should work fine as
: long as everything spins "ture"
: when finished. ( there is no real load on
: this section of the shaft, it's just for
: location / support)
: If someone out there has the
: "lay-out" or measurments on this
: special tip, let us know.
: DD
I dont have the specific meaurements for a T5,,,but used this process to put a Ford RAP 5 speed in my Valiant....I just took the Valiant box and the Mustang box to my machinist,,,said "make this one look like this one"...it helps to have a pilot bushing on hand. I also had to have him machine down the input bearing retainer to take the slant throwup bearing,,,,and more importantly match the register in the Valiant bellhousing. It cost me about $60 US for machine work,,,use the 5 speed clutch disc and Valiant pressure plate.
The bellhousing modifications and rear mount are the difficult parts of this swap.
Still not sure why you guys dont just jump in,,,is it hard to get a good machinist?
PostPosted: Sat Oct 06, 2001 6:30 am
aus dollar is buying 49-50 US cents.. rarely changes.. makes it easy to work out eh!
