| transmission https://slantsix.org/forum/viewtopic.php?t=2734 |
| Author: | Jimi [ Fri Oct 05, 2001 9:58 pm ] |
| Post subject: | transmission |
am in dire strait-64 Ply Valiant conv. with pushbutton shift needs auto trans-unable to locate in Long Bch.-So.Bay area of So.Ca. area. Also, need to know what yr. make etc. is compatible; trans in Val. won't shift forward simply winds eng. |
| Author: | Dart270 [ Fri Oct 05, 2001 10:12 pm ] |
| Post subject: | Re: transmission |
: am in dire strait-64 Ply Valiant conv. with : pushbutton shift needs auto trans-unable to : locate in Long Bch.-So.Bay area of So.Ca. : area. Also, need to know what yr. make etc. : is compatible; trans in Val. won't shift : forward simply winds eng. Jimi, I have an A904 out of a '64 Dart - same trans you have - that you can have for $10. I'm in Pasadena. I have no idea if it works or not as I've never used it, but you could get it rebuilt or use parts from it. Came out of a car with 170k on it and according to the owner, it worked at that point. Let me know and we can set something up. Lou madsenl@caltech.edu |
