It is currently Fri Nov 20, 2026 8:13 pm
PostPosted: Fri Feb 22, 2008 11:29 am
I'm accumulating parts for my /6 build and am looking for a timing chain right now. Is a double roller necessary when building a hot /6? If so, where can you buy them? I haven't seen any other than the stock type chains.
Also, I assume a double roller fits just fine under the stock timing cover and fits on the same as a stock unit?
Thanks
Stephan Nelle
PostPosted: Fri Feb 22, 2008 12:56 pm
Double roller will be more durable and if you run a big cam with Higher valve spring pressures probably a wise investment.
Here are some options
and they fit under a stock cover.
http://www.slantsix.org/forum/viewtopic.php?t=11426
http://www.slantsix.org/forum/viewtopic.php?t=18147
http://www.slantsix.org/forum/viewtopic.php?t=26369
Hope this helps, Greg
Users browsing this forum: Amazon [Bot], Google [Bot] and 5 guests
