It is currently Wed May 27, 2026 6:21 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: Crane 99604
PostPosted: Sat Oct 06, 2001 11:16 pm
This part number (distributor advance spring kit) has been discontinued. I've inlisted the help of the local "speed shop" owner, who thinks Mallory ignition springs might do the trick. I'll pass along any info I get.
Fourgasman@aol.com
 Post subject: Re: Crane 99604
PostPosted: Sun Oct 07, 2001 9:09 am
: This part number (distributor advance spring
: kit) has been discontinued. I've inlisted
: the help of the local "speed shop"
: owner, who thinks Mallory ignition springs
: might do the trick. I'll pass along any info
: I get.
A small block Mopar kit shoud have everything you need,
To bad that Crane kit is now discon., that was a great kit. It the 99605 kit a "dodo bird" also?
Keep us posted on what you find.
PostPosted: Sun Oct 07, 2001 8:28 pm
Didn't ask about the "points" kit, but assume it's gone as well. The shop owner asked if it would be posible to use the "light" spring from a diferent distributor to get to total advance a little faster, but even the light spring looks like a real battle ship! Hope my converter is loose enough....
Fourgasman@aol.com
PostPosted: Mon Oct 08, 2001 8:39 am
: Didn't ask about the "points" kit,
: but assume it's gone as well. The shop owner
: asked if it would be posible to use the
: "light" spring from a diferent
: distributor to get to total advance a little
: faster, but even the light spring looks like
: a real battle ship! Hope my converter is
: loose enough....
I have used the springs out of other Mopar distributors, even SL6 distributors have a wide range of spring combos. (170 vs 225, Light cars, Heavy trucks etc.)
Go to the wrecking yardss and "gut-out" a few distbs., that will give you some springs to work with.
Sad thing about "loosing" this "Kit" is that the spring combos were already worked-out, pretty close to optimized, this saved on "trial & error" time.
