| rear main seal https://slantsix.org/forum/viewtopic.php?t=27390 |
| Author: | kit [ Sat Feb 23, 2008 10:11 pm ] |
| Post subject: | rear main seal |
I have replaced the rear main seal on my van twice, and it still leaks. Is there any speedy sleeve for this 1979 slant 6 or another kind of seal that works better? has any one else had this problem? |
| Author: | rock [ Sun Feb 24, 2008 5:54 am ] |
| Post subject: | Kit, are you certain you put the seal in with the lip in the |
Hi Kit, In a hurried moment I almost put one of the seals in backwards once. VERY easy to do, are you certain the lip is pointing the right way? I ask cause I have never had one fail.....oh did you also use a torque wrench to tighten the aluminum seal block under the crank rather than guess at if it was tight enough? It's more important than many torques.. rock '64d100 |
