It is currently Thu Jul 16, 2026 8:11 pm
 Post subject: best time ever
PostPosted: Sun Oct 07, 2001 3:44 pm
Short version update: 66 cuda, 170CID, 3100LBS
13.897 AT 95.68 MPH 1/4 mile
13.884 AT 95.80 MPH
6200 RPM IN THE TRAPS
Still together to run next week.
Charlie
flturbo6@aol.com
 Post subject: Re: best time ever
PostPosted: Sun Oct 07, 2001 9:08 pm
: Short version update: 66 cuda, 170CID, 3100LBS
: 13.897 AT 95.68 MPH 1/4 mile
: 13.884 AT 95.80 MPH
: 6200 RPM IN THE TRAPS
: Still together to run next week.
: Charlie
Pretty darn good! planed any changes for next time ?
damuel@kalam.com
PostPosted: Sun Oct 07, 2001 9:59 pm
: Pretty darn good! planed any changes for next
: time ?
next time hope to get to the track earlier, and do some jetting and timeimg changes
flturbo6@aol.com
PostPosted: Sun Oct 07, 2001 10:22 pm
: next time hope to get to the track earlier, and
: do some jetting and timeimg changes
On the juce?
Will
slantsix@netzero.net
PostPosted: Mon Oct 08, 2001 7:33 am
: On the juce?
: Will
Going to try and set up another distributor, this week. Want to see how it works with the nitrous.
P.S. Is this Will Burns, low down cuda?
Charlie
flturbo6@aol.com
PostPosted: Mon Oct 08, 2001 8:49 am
: Going to try and set up another distributor,
: this week. Want to see how it works with the
: nitrous.
: P.S. Is this Will Burns, low down cuda?
: Charlie
Way to go Charlie, Kinda makes me want to get my 170 back into my 68 Cuda. ( I have a "back-up" 225 in there at the moment)
I did hear that you "sprayed your way" into the 13s, how big was the "hit"? Is this a plate or fogger system?
(and yes, that is "So Low Cuda" Will B. (@netzero) Better known as "the man of few words" when it comes to posts ;-)
PostPosted: Mon Oct 08, 2001 11:16 am
: I did hear that you "sprayed your
: way" into the 13s, how big was the
: "hit"? Is this a plate or fogger
: system?
: (and yes, that is "So Low Cuda" Will
: B. (@netzero) Better known as "the man
: of few words" when it comes to posts
Hi Doug,
First off I met Will at Clay City. Talked to him, Charles Myers, the Cox Bros, and others about running Nitrous on a slant six. I would like to thank all of them for their help. The system i have is a fogger on a factory cast iron manifold with a holley flange welded on, and a 500 cfm holley 2bbl carb. Right now I'm spraying about 130 hp.The motor is very mild. TRW forged stock replacement pistons, head milled .090, no other head work. Cam is a crane 222* dur at .050 and .434 lift. Deep pan, windage tray, and mods to the oiling system similar to yours. clifford 3into2 headers, electronic dist with msd 6 box. Push button 904 with 8 inch convertor. 3.91 suregrip 7 1/4 rear. Car is a 66 cuda full street legal, weighs 3100 lbs with me in it.
flturbo6@aol.com
