It is currently Tue Nov 17, 2026 1:01 pm
 Post subject: 904 shift lever seals
PostPosted: Thu Feb 28, 2008 12:09 pm
hello,
I am preparing to do an oil, trans filter and seal change on my 904 and i just needed to know where can i get the seals for the shift lever, and how to repalce them, as it seems to leak from there.
thanks for the help.
'Sup
PostPosted: Thu Feb 28, 2008 2:39 pm
I've bought them at NAPA in the past.
Just about every Mopar with automatic I have bought has had a leaky selector shaft seal.
There is a tool to remove the seal without droping the VB, and I think one to reinstall. I just drop the VB, knock the out one out from the bottom, then pull the new one in with a bolt, nut and washers. The hardest part is pulling the new seal in flush without getting cocked.
Slant Cecil
PostPosted: Thu Feb 28, 2008 4:49 pm
Thanks a lot.
I was searching into past posts about adjusting transmission bands, can anybody give me a quick how to, or give me the link of a good procedure.
thanks a lot again
chargerucd
'Sup
PostPosted: Mon Mar 10, 2008 12:27 pm
Hello,
already removed the pan and it looks warped, I'll be replacing that. but if i remove the valve body, should i just do the shift kit while in there?
just wondering
thanks for the help
'Sup
PostPosted: Mon Mar 10, 2008 9:08 pm
I posted the timken number in the parts list on the main page years ago, it is still there I think. Called selector shaft seal I think.
When I did this seal before, with the valve body out, pry out the old seal. Next get a bolt and nut combo that will allow you to press the seal in from underneath.
I would install the shift kit since you already have the valve body out(while your at it, drain the torque converter, most, not all, 904's have a drain plug on the front of the TC, behind the inspection/dust cover). Installing the shift kit is realtively painless, just make sure you have a clean work surface and keep track of what you are doing. Most kits come with two stages, I did the stage one, and I can't imagine a stage 2 being tolerable as a daily driver. But to each his own.
My Swinger gets the Highlight Valet Parking spot over the German sports cars on the Sunset Strip. I love my Mopar.
PostPosted: Wed Mar 12, 2008 7:23 am
On that topic,
Anybody tried the mopar performance part # P4007899, it says is the shift improvement kit. or is the B&M kit a lot better?
thanks
'Sup
PostPosted: Fri Mar 14, 2008 3:07 pm
I just got that selector seal install/remover tool from E-Bay $10! Sweet!
I used the B and M kit. Have had no problems. Easy install. Many people will tell you that the TransGo kit is the way to go. I have never seen any scientific evidence for this. Never used the Mopar Kit, I wonder who makes it for them? Hmmm...
Anyway, installing a kit will help prolong the life of your transmission bands, and I like the firmer shifts.
