It is currently Tue Nov 17, 2026 6:35 am
 Post subject: Truck 904
PostPosted: Thu Feb 28, 2008 7:24 pm
Are the truck 904's for slants any stronger than the car units? Also how do you ID a lock-up from a non lock-up from the outside?
Thanks for any info.
Franklin
'61 Valiant
PostPosted: Fri Feb 29, 2008 6:25 am
I don't know for sure, but they may have more clutches (4 vs. 3 front and 3 vs. 2 rear?) and possibly 4 pinion planetaries, but that is just a guess. Most V8 904s had these, and you can swap the guts into a slant 904 case.
You can tell it's a lockup trans because the inner input shaft will have a machined lip on the end about 3/8" with no splines on it to seal to the lockup drive (splines are turned down to a smooth shaft). Regular trans has splines all the way to the end.
PostPosted: Tue Mar 18, 2008 2:02 pm
from my reading about the difference is both are just as strong. truck 904s from my reading have a longer end sections making the driveshaft shorter vs passanger car 904s. i could be wrong as this is just from my reading over at FABO.
1976 Plymouth Feather Duster
2002 Dodge Dakota 4.7l v8
PostPosted: Tue Mar 18, 2008 6:13 pm
I haven't seen a short 904 TS on trucks, they're the same as cars.
Trucks with a 727 have a short and long TS, depends on application. The long TS is heavy duty and can be ID'd by the snap ring cover at 2:00 instead of the car's 6:00.
Easiest way to ID a lock up trans is the 1/2" nub on the end of the input shaft. If it's in the car/truck, look for the activation wire going into the left side of the case.
Slant Cecil
