It is currently Tue Nov 17, 2026 10:11 pm
 Post subject: 904 to A-833OD
PostPosted: Tue Feb 26, 2008 12:36 pm
Well I wasn't planning on doing the swap just yet but found a 4-speed 833 from a 79 pick-up ( long tail shaft ) for $200 for everything (peddles, linkage, shifter ). Should I try to get it? I'd love to have a 4-speed for the increased fun and mileage factors.
PostPosted: Tue Feb 26, 2008 2:42 pm
If you're going to put it in a pickup sure, get it. Don't forget the clutch, bellhousing, flywheel, etc. Make sure you can put a pilot bushing in your crank.
 Post subject: Re: 904 to A-833OD
PostPosted: Fri Feb 29, 2008 7:53 am
What is the A-833 O.D. trans being installed in?
