What years low 1st/2nd gears in SL6 904AT
https://slantsix.org/forum/viewtopic.php?t=27580
Page 1 of 1
Author:  Warren@PDX.com [ Sun Mar 02, 2008 1:02 am ]
Post subject:  What years low 1st/2nd gears in SL6 904AT
I have a '80 Volare 225 w/904 non-lock-up.Isn't this the first year for the lower 1st & 2nd gear ratios in the SL6 904 trans?I also have an el-cheapo delux torque convertor with 200+/- higher stall. Later on I will install a 4spd/OD package (w/IRON case 833OD)I got out of a wrecked Volare S.W.
Author:  SlantSixDan [ Sun Mar 02, 2008 5:50 am ]
Yep, your '80 has the wide-ratio gearset in the automatic trans.
Author:  Warren@PDX.com [ Sun Mar 02, 2008 12:45 pm ]
Post subject:  Wide ratio trans
Sweet! Thanks SL6 Dan for the info,now I know there's no hurry to swap 833OD setup into the Volare.
