It is currently Tue Nov 17, 2026 3:43 pm
PostPosted: Sun Mar 02, 2008 1:02 am
I have a '80 Volare 225 w/904 non-lock-up.Isn't this the first year for the lower 1st & 2nd gear ratios in the SL6 904 trans?I also have an el-cheapo delux torque convertor with 200+/- higher stall. Later on I will install a 4spd/OD package (w/IRON case 833OD)I got out of a wrecked Volare S.W.
"Faith in Science"
PostPosted: Sun Mar 02, 2008 5:50 am
Yep, your '80 has the wide-ratio gearset in the automatic trans.
 Post subject: Wide ratio trans
PostPosted: Sun Mar 02, 2008 12:45 pm
Sweet! Thanks SL6 Dan for the info,now I know there's no hurry to swap 833OD setup into the Volare.
"Faith in Science"
