It is currently Fri Nov 20, 2026 9:36 pm
 Post subject: Isky Groove-O-Matic
PostPosted: Fri Feb 22, 2008 2:29 pm
Well, I rented the Groove-O-Matic to install o-rings in the block. It seems like a pretty nice tool. It is very compact and I should have no problems grooving the block while it is in the car. I put it in a bore and tightened it up to see how it would run in the bore. Seems to turn in the bore very nicely without any drag. Wish me luck.
 Post subject: good luck!
PostPosted: Fri Feb 22, 2008 3:14 pm
good luck , sounds like a fun weekend!!! :D
63 valiant v200 Wagon 9.5, Schneider cam, E.I. 22 mpg all day
PostPosted: Fri Feb 22, 2008 3:26 pm
Never heard of this tool before. Details?
PostPosted: Fri Feb 22, 2008 4:33 pm
2/3 of the way down it shows one in use.
http://www.cumminsracing.com/images/hea ... t_0250.jpg
PostPosted: Fri Feb 22, 2008 4:39 pm
so will you be grooving the head as well and what gasket are you using :?:
PostPosted: Fri Feb 22, 2008 6:53 pm
I have a copper head gasket and will be grooving the block only. There is no way for this tool to work on a head. It depends on the depth of the cyl bore to help center/stabilize the tool.
 Post subject: why?
PostPosted: Fri Feb 22, 2008 9:26 pm
Car Model: 1968 A108 225/3 on the tree
what is the purpose of the groove? how big/deep is it? is it in the deck surface or in the cylinder bore?
D~~~!
 Post subject: I think
PostPosted: Fri Feb 22, 2008 10:07 pm
I think he's putting a groove around each cylinder so that he can run metal o-rings to get a handle on extreme compression.
madam im adam
PostPosted: Sat Feb 23, 2008 5:28 am
The tool will cut a groove around the cylinders approximately .030" deep and .038" wide so a copper wire .040" wide can be inserted into the groove. This gives a positive bite into the head gasket to help eliminate blown head gaskets. It is mainly used in turbo, supercharger and NO2 applications because of the higher cylinder pressures.
PostPosted: Sat Feb 23, 2008 5:49 am
That's great shaker. Be sure to post some pics of the results.
OK, NO ONE is going to go for the obvious joke and say that tool looks groovy? :lol:
DynoDave
1970 Plymouth Duster
1972 Dodge Charger Rallye
1977 Chrysler Cordoba
WPC # 12304
PostPosted: Sun Mar 02, 2008 3:54 pm
Here is a pic of a groove and an o-ring installed and one with the studs and gasket in place.
Just waiting for the head to be finished up.
I cant get a pic to post so see: here
And here too
PostPosted: Sun Mar 02, 2008 4:52 pm
Interesting. Is that copper wire?
PostPosted: Sun Mar 02, 2008 5:31 pm
Yeah, it's .040". It sticks up .011" to .013" to bite into the gasket. I've seen staunless wire used before too.
Users browsing this forum: Google [Bot] and 11 guests
