It is currently Sat Nov 21, 2026 5:56 pm
 Post subject: METAL or NYLON?
PostPosted: Fri Mar 07, 2008 5:47 pm
Is the factory nylon ditributor gear a weak link? Is steel or bronze available? Pro's and con's of each. THANKS.
PostPosted: Fri Mar 07, 2008 8:08 pm
The factory nylon pinion is not a weak link at all. They routinely last for decades. Metal pinions are out there (costly) if for some reason you've gotta have one.
PostPosted: Sat Mar 08, 2008 7:02 am
Remember, on a V8, the distributor gear also drives the oil pump. On a slant six, it doesn't have to spin anything besides the distributor as the oil pump runs on a separate gear.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sat Mar 08, 2008 1:32 pm
I broke the nylon gear once when I took the distributor out for the first time. It went bad anyway so no loss on my part.
PostPosted: Sat Mar 08, 2008 3:19 pm
I broke a few of them before I realized the distributor was broken too.
1963 Dodge Dart -225 Slant 6, 904, 2.76's, 18.84 @ 73
1970 Nova 12.53@108
1970 Bug 15.38@87
Users browsing this forum: Amazon [Bot] and 4 guests
