METAL or NYLON?
https://slantsix.org/forum/viewtopic.php?t=27697
Author:  thomasj6604 [ Fri Mar 07, 2008 5:47 pm ]
Post subject:  METAL or NYLON?
Is the factory nylon ditributor gear a weak link? Is steel or bronze available? Pro's and con's of each. THANKS.
Author:  SlantSixDan [ Fri Mar 07, 2008 8:08 pm ]
The factory nylon pinion is not a weak link at all. They routinely last for decades. Metal pinions are out there (costly) if for some reason you've gotta have one.
Author:  Matt Cramer [ Sat Mar 08, 2008 7:02 am ]
Remember, on a V8, the distributor gear also drives the oil pump. On a slant six, it doesn't have to spin anything besides the distributor as the oil pump runs on a separate gear.
Author:  ESP47 [ Sat Mar 08, 2008 1:32 pm ]
I broke the nylon gear once when I took the distributor out for the first time. It went bad anyway so no loss on my part.
Author:  Davids63Dart [ Sat Mar 08, 2008 3:19 pm ]
I broke a few of them before I realized the distributor was broken too.
