It is currently Tue Nov 17, 2026 1:34 am
 Post subject: 7 1/4 question
PostPosted: Sat Mar 08, 2008 6:25 pm
where can i get a sure grip setup for a 7 1/4. I have not opened mine but i pretty sure its not right now. The car is a 1977 Plymouth Volare with a 225/6 one bbl carb. Any help would be nice b/c i want to set it up for drag this year.
PostPosted: Sat Mar 08, 2008 6:34 pm
Post on all the different Mopar boards in the PARTS WANTED section.
:D
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Mar 11, 2008 7:50 pm
if you're going to drag race it, you can take and weld the spider gears in the differential together, make yourself a spool. But then it would be a bitch to drive.
PostPosted: Tue Mar 11, 2008 8:02 pm
plus if you weld in the diff your axle and side gears are gone for further use, they might break too. thats why a real spool is nice, you can take it out and not modify your needed parts
'72 Valiant DD for over a decade-225-Disc brakes, big T-bars, big Sway bars f/r, carter bbd/super six, GM HEI, 2- 12" subs in trunk, 1000w amp...
'77 cherokee cheif widetrack-360-33x12.5 tires-no lift. keeps driveway dry-project/backup DD/mudder
PostPosted: Tue Mar 11, 2008 11:49 pm
Car Model: Toad Wagon
Here's one.
And possibly another.
Sex, drags, and rock & roll.
Dick, 225% crazy.
 Post subject: where do i get one
PostPosted: Fri Mar 21, 2008 10:53 pm
Where do i get a spool. I haven't been able to find one. I would use one from another rear end if i could find one to fit. Any help would be grateful.
Users browsing this forum: Amazon [Bot] and 2 guests
