7 1/4 question
https://slantsix.org/forum/viewtopic.php?t=27715
Author:  volare320hp [ Sat Mar 08, 2008 6:25 pm ]
Post subject:  7 1/4 question
where can i get a sure grip setup for a 7 1/4. I have not opened mine but i pretty sure its not right now. The car is a 1977 Plymouth Volare with a 225/6 one bbl carb. Any help would be nice b/c i want to set it up for drag this year.
Author:  66aCUDA [ Sat Mar 08, 2008 6:34 pm ]
Post on all the different Mopar boards in the PARTS WANTED section.
:D
Frank
Author:  derranged-gadgeteer [ Tue Mar 11, 2008 7:50 pm ]
if you're going to drag race it, you can take and weld the spider gears in the differential together, make yourself a spool. But then it would be a bitch to drive.
Author:  dank10fenny [ Tue Mar 11, 2008 8:02 pm ]
plus if you weld in the diff your axle and side gears are gone for further use, they might break too. thats why a real spool is nice, you can take it out and not modify your needed parts
Author:  Old6rodder [ Tue Mar 11, 2008 11:49 pm ]
Here's one.
And possibly another.
Author:  volare320hp [ Fri Mar 21, 2008 10:53 pm ]
Post subject:  where do i get one
Where do i get a spool. I haven't been able to find one. I would use one from another rear end if i could find one to fit. Any help would be grateful.
