It is currently Sat Jul 18, 2026 1:49 am
PostPosted: Sun Mar 09, 2008 11:57 pm
Well, I have at last got the old beast running. I bought my 66 Valiant V200 for 300 bucks and trailered her home. After many weeks and curse works, and some absolutely awesome help from Dusteridiot, I was able to finally get her cranked up after sitting for 12 years.
There are 2 things that are weird, and I have thoughts on one, the other I don't know..
#1, The engine misfire is not caused by lack of spark or fuel to the cylinder. I know this because taking the plug out and laying it on the valve cover during cranking shows good spark.
I also know that it is getting fuel because after running the engine for just a short time, the plug is usually covered with gasoline.
So, in my opinion the only thing missing is compression. There are 2 options, the valves aren't sealing, and/or the rings are not sealing.
When running, if i blip the throttle, I get smoke spurts from the oil pan through the dippy, and out the valve cover vent. So this tells me that I have bad rings and/or rings that just aren't sealing due to lack of use.
The other thing would be valves/valve seats, but I really don't feel froggy enough to take it apart unless I am 100% sure that it needs to be done.
The same color smoke that I get from the oil pan and valve cover is coming out of the exhaust, and it smells like burning wood. Wood being burnt by say a router, not actually a fire. Friction is the word I am looking for.
I let it come to operating temperature, and nothing changes. I know its been sitting for some time now, and that pretty much nothing is sealing, so what is a good way to "break in" an old engine?
Its got a new timing set, water pump, ballast resistor, condenser, coil, and plugs.
Dusteridiot came to my house and set the cam and ignition timing for me, so I know that these 2 things are good. But as far as internal issues, I have no idea.
~The other Rob~
PostPosted: Mon Mar 10, 2008 2:12 am
dont forget head gasket!compression and leak down test time. a leak down test will put pressurised air in the cyl. you can then grab your stethoscope and listen for air. exhaust pipe(exhaust valve), intake(intake valve),crankcase(rings/headgasket/random) sometimes you can see bubbles in radiator. we actualy got a chick in our auto program to listen in th P/S pump cuz thats why the car "had a misfire while turning" :lol: :roll:
'72 Valiant DD for over a decade-225-Disc brakes, big T-bars, big Sway bars f/r, carter bbd/super six, GM HEI, 2- 12" subs in trunk, 1000w amp...
'77 cherokee cheif widetrack-360-33x12.5 tires-no lift. keeps driveway dry-project/backup DD/mudder
PostPosted: Mon Mar 10, 2008 4:01 am
If that plug is wet then its gas fouled even if it does show to be sparking. When it gets under load it will not. Put a new plug in it and try a spare new plug wire with it, or atleast swap it wire the wire on a differnt cylinder to see if the dead cylinder moves with it. BUt new plug will be needed, not cleaning it.
Jess
PostPosted: Mon Mar 10, 2008 7:02 am
I did actually replace that single wire to see if that would fix it... to no avail, and I installed a new plug into that cylinder, and that didnt fix it either.
I would try a leakdown test on it, but at the moment, I dont have a compression or cylinder leackage tester to do that with.
~The Other Rob~
PostPosted: Mon Mar 10, 2008 9:19 am
Have you checked the valve lash?
PostPosted: Tue Mar 11, 2008 8:43 am
Should be able to check it in the next few days, I'll post what I get when they are measured.
PostPosted: Tue Mar 11, 2008 7:11 pm
So now I know for sure that it is a compression issue. So I tore the head off... all of the bolts holding the manifold came off ok, the studs on all but 2 came with the nuts, but that is better than breaking them all.
I took the head off, and not to my surprise, the #5 piston has a small chunk missing off the side of it. So thats why #5 is dead,
The #3 exhaust valve isnt round anymore, its wobbly shaped, and not sealing for beans, so thats why it didnt do well at all.
#1, I cant really figure out exactly what is wrong with it at them moment, but I'll find out when I clean everything up.
Users browsing this forum: Amazon [Bot] and 4 guests
