It is currently Sun Nov 29, 2026 12:50 am
PostPosted: Fri Mar 14, 2008 11:32 am
How can I get them out of my instrument cluster?
Ronnie
http://www.cardomain.com/ride/2714941
PostPosted: Fri Mar 14, 2008 11:35 am
The knob on the wiper switch may have a set screw in it. The light switch has a push button you depress and then the knob and shaft pull out. The button is usually located on top of the switch body and a PITA to get to sometimes, especially if you have large hands.
PostPosted: Fri Mar 14, 2008 2:02 pm
See this post for tips on headlamp knob/stem removal. The wiper knob will indeed have a setscrew. Once you've removed the wiper knob and the light knob/stem, the switches themselves are held on with ring nuts.
PostPosted: Fri Mar 14, 2008 2:49 pm
I got it thanks for the replies.
Ronnie
