It is currently Tue May 19, 2026 9:10 pm
PostPosted: Sat Oct 20, 2001 4:48 am
Help!!!
I'm looking for an air cleaner base complete ( with sensor and vacuum switch for heat door) for my 86 Van 150 - the parts shops say they can't get them anymore and Dodge says no go also even the junk yards don't seem to have any around here(Boston)!!! anyone have an idea or parts kicking around for sale??? van takes forever to heat up,and stalls till it's warm. Thanks
kenfitz@juno.com
PostPosted: Sat Oct 20, 2001 6:29 am
I've seen them in salvage yards around here in Minnesota. Is yours that one with the offset aircleaner? What exactly do you need? the complete aircleaner housing or just the sensor for the heat door?
cfield@ll.net
PostPosted: Sat Oct 20, 2001 3:26 pm
: I've seen them in salvage yards around here in
: Minnesota. Is yours that one with the offset
: aircleaner? What exactly do you need? the
: complete aircleaner housing or just the
: sensor for the heat door?
Hi, Craig,
I'm looking for the whole air cleaner base, or just the Trap door vacuum switch and the small heat sensor clipped to the inside of the base. I'm not sure what the off set is, mine is slightly off centre. The number on the top of the heat door switch is # 42135 /15. below that is a # 32550 it's a Dodge part # the sensor inside the base just says "made in Canada ". I'd be very glad to compensate you for your time and trouble and the part and shipping if you happen to run across one ......that's also a shout out to anyone else out there if you have any ideas on where I can get my hot little hands on one. It's getting chilly now and my Van takes forever to warm up and not stall....Help!!!!
kenfitz@juon.com
