It is currently Mon May 11, 2026 6:55 am
PostPosted: Sat Mar 15, 2008 4:04 am
I have a 74 dart with a 225, the car currently has a chrome valve cover on it, i want to replace it with a stock valve cover. I got one from a 67 dart at the junkyard, wondering if i can use it. The reason i ask is that it only has 2 holes in it, one for the oil that has a stack and one for the pcv. the original one had 3 holes in it (one for oil, one for pcv, one for breather that hooks to air cleaner).
PostPosted: Sat Mar 15, 2008 4:38 am
Yes you just pore the oil down the same hole that has the breather on the tube/stack ( after pulling out the breather cap that goes to the carb breather) I think I said all this right.
Jess
PostPosted: Sat Mar 15, 2008 5:26 am
Yes, that'a correct. The breather tube doubles as a fill port. It should work just fine.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Mar 15, 2008 5:57 am
My question is, on the current setup, the breather vents into the air cleaner, this valve cover would not do that, will that have adverse effects?
PostPosted: Sat Mar 15, 2008 8:29 am
No it allows air into the engine. Just use a cap with a good filter. I use a K&N for mine but there allot of other good choices.
PostPosted: Sat Mar 15, 2008 8:58 pm
You can go to Vatozone or Poop Boys and get a chrome push-in filler/breather for about $10. I believe they also have the new grommets there too. :shock:
